Wiper Arm
A1218
Car: 1997 Nissan Pathfinder SE
Anyone know if any aftermarket wiper arms work on the 1997 Pathfinders? My front wiper arms seems to be a bit bent from this past winter somehow and I cannot find any dealer or Nissan part website that has them.
They tend to clatter even when new blades are used.
Thanks
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Nissan Pathfinder Wiper Arms
Model years 1996-2004
Position: Right
Nissan Part No.:28886-0W000
https://www.nissanoempartsdirect.com/oe ... O8QAvD_BwE
Google search results: https://www.google.com/search?client=fi ... 8886-0W000
Position: Left
Nissan Part No.:28881-0W000
https://www.nissanoempartsdirect.com/oe ... EsQAvD_BwE
Google search results: https://www.google.com/search?client=fi ... 8881-0W000
A1218
They’re actually not in stock. I’ve called around, even those websites. The passenger side they might be able to get in a month.They all said the driver side there’s one left in the entire country and most likely it’s not there anymore.
Rogue One
2022 Honda Pilot SE
Well, it was worth a shot. Plan B is to check the used inventory. https://www.car-part.com/
mdmellott
Car: '13 Kia Soul+ 2.0L AT
Some parts just aren't available as aftermarket parts. Rogue One's plan B is your best bet. I found them, from an old 2001 Pathfinder, at AH Parts for $10 each but it will probably cost just as much to ship them unless you live near Rancho Cordova, CA, where they are located.
https://ahparts.com/buy-used/2001-nissa ... 1/239314-1
https://ahparts.com/buy-used/2001-nissa ... 1/239315-1
A1218
Okay guys will check it out.
Thanks for the help!
Mike W.
Car: 2003 Infiniti QX4 with a drinking problem. Gone but not forgotten
2002 BMW 525it
2002 BMW 530i/ manual trans
The dark side, 2008 4Runner.. We'll see.
New blades aren't all the same. I've installed new ones, from good manufacturers even, but their budget line that chattered when new. Bosch is usually a good brand, but some of the worst blades I've had have been Bosch. Unless, maybe, someone was trying to turn them into a pretzel, a modestly bent arm shouldn't cause chatter, that's the blade.
Now cosmetics may drive you crazy and necessitate replacement, but that's a want not a need.
A1218
Haha
Which blades have you found to be the most decent?
