Wiper arm removal
bajahammer21
I am trying to replace the driver side cowl and need to remove the wipers? I have removed the cap and bolt but the arm doesn't seem to slide off. Is there a step I am missing or do I need to force it off?
Nonsense
Car: s14 zenki
Try to Wiggle it and Pull it towards you.It should pop off
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
they tend to stick, might be a good idea to hit it with some penetrating oil and if it won't wiggle off you might considder using a puller
Z_Fanatic
Car: 91 300zx TT Conversion, 01 Bmw 325I DD
I've done this a couple times in junkyards, the best way is to grab a screwdriver and a hammer of some sort, GENTLY pry from underneath with the screwdriver while tapping the top of the bolt with the hammer. Don't bang on it, just give it a couple taps, should pop off. Usually sounds like a gunshot when it finally comes off.
chaz63
Car: 1991 Nissan 300zx
base model
non turbo
t tops
automatic
Best way I found is using a small gear puller.
BlackWidowZ
Car: Black 93 300zx 2+2
If you pull on it, it doesn't pull strait because you are pulling from the wiper arm so it is tilting and not coming out strait. Hit is with some pb blaster or wd 40, then tap on it with a hammer as you wiggle on it. It won't come off easy. eventually after tapping it with the hammer, pb blaster and wiggling it all at the same time it will come right off, just rock it back and forth while doing all of the things till it aligns up strait and pull it off strait. ;)
I would advise aginst prying it with anything, your liable to break, crack dent, scratch something.
this is for a rear wiper delete but use similar method of removal .
http://www.youtube.com/watch?v=7HmF-rlCh5E
300ZXttZMAN
chaz63 wrote:Best way I found is using a small gear puller.
Welcome to NICO! Make a new thread and post your into with pics!
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Zombie thread!!!
Jwaite132
Car: ???
So the easiest way I found out is to take off the bolt then move them up to the middle of the windshield and lift them up like your about to wash your windshield and they should just lift off easily
