WINTERIZING
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
charliej13
Car: 1965 nl320
1964 l320
Is opening the petcock behind the distributor and draining coolant there enough to be safe ? or is there another place to drain engine?
Li'l Truckie
Car: 3 x '65 PL 320
1 x '64 PL 320
1 x '63 PL 320
1 x '62 PL 320 - parts :(
1 x '60 PLG-222
and many more Datsuns from 48hp to over 500hp
charliej13,
If you are draining the complete system then use the drain under the radiator on the right side. If only the draining the block then yes the drain right rear of the block will do - you will also drain the radiator down halfway down as the coolant levels out. Just a heads up that this drain is usually clog with rust particles from the block. It will still make quite a mess as you turn the valve the stream of coolant will go every which way and trying to catch the coolant in a pan or bucket is somewhat futile with everything in the way.
Andy
Return to “Datsun 320”
