Winterizing and tuning the J
93jdirty'
Car: 1993 Infiniti J30
Hey guys ive been here for a while and come on everyday(allthought i have not posted much) i read all the posts in all the forums. so whats up guys. anyway..sorry about the long post
winter is coming and there is quite a few things to do to the j such as1. windshield rubber stripping needs replacing, where to get done?
2. tune up? i have a fresh K@n, clean oil what else should i change?
3. i am unaware if my timing belt has been changed. My car has 129 k and seems to run fine, what to do?
4. Tires, i have summer high performance tires, where can i get some cheap but good winters?
5. I have some rust on the front of the sunroof, and bottom of fender if i spray some auto paint on it will it prevent further rusting?
6. i cant wait to show some pictures of the J
Jakw
Car: 1993 J30
1. I'd check with an auto glass place. If they don't do it, they might know who does.
2. Depends on how long it's been. Get all your fluids checked, check out the plugs maybe, just basic maintenance stuff at least.
2. There is a major service due at 120k miles, which includes all belts/pullies/tensioners/main seal among other things. If it's not, you're pushing your luck. If you need it done, I hope you have some cash saved. It's not cheap.
I usually check tirerack.com, but local places might charge more for mounting and balancing if you just bring them tires, so I'd check local if I were you.
Rust is like cancer. Paint will cover it for now, but it will eventually just bubble the paint, and you'll end up with more rust underneath the paint than you think. So what you need to do is go to a body shop, have them sand out all the rust, fill it, and paint it. I need this done along the doors/rocker area, and I was quoted at $350 for one side of the car at a local shop. Check around for that stuff too.
yodawill2000
Car: 94 Infiniti J30
Look at the metal plate at the front edge under the hood and see if it states the mileage of the Timing belt change.If your on the original 93 T belt its a time bomb waiting to thrash your engine.
Jakw
Car: 1993 J30
Oh yeah, for tuning up, there's probably more you can do. If your throttle bodies are dirty, clean them. I've heard of it making hesitation stop. Same with cleaning the MAF sensor. Maybe run some Seafoam through it, it's worked wonders for plenty of people.
