I guess that would make to much sense for them to do that.dividedhighw wrote:No, and ...
No ... it wouldn't be much "fun". That's why I plan to simply tolerate the idiot light, as I said in this thread.
Cheers,David
Cheers,David
Nokian Hakkapeliitta are AMAZING in the snow, but are not very good in the dry and wet. They are also very noisy and are Q-rated so you can't go over 160 km/h. (100 MPH)morning_glory wrote:Living in the northen part of quebec I have a solid experience with winter tires.
In the last ten years I drove some suv's and the tires I used were Blizzak, Toyo, Nokian and GoodYear.The best performances I got were from Nokian and Toyo.
For my EX I just bought 4 x 18" Nokian Hakkapeliitta (approx. 1100$CN with taxes).
Er ... I assume you meant 17" would be less expensive.ThinkingAboutIt wrote:It appears that 18inch are more expensive and that 20inch would be quite a bit less expensive.
Does that figure include shipping, on-wheel mounting, nitrogen fill, balancing, on-vehicle mounting, tax, etc? (If not, I might be able to get you 17" alloy wheels and the same Toyo tires I mentioned, at around that same price point.)ThinkingAboutIt wrote:Edmonton Tires - because that is the only source I have found that has an inventory of 18inch winter tires. Price of steel wheels and four 18inch Yokohmas is $1428.
YES ... these issues can exist even if you use the same tire size - I discussed the most important aspect above (in my post 5:40 PM 10/9/2008). If there's something in my previous post you don't understand, just ask and I'll be happy to clarify. For brevity's sake, I didn't go into an explanation of what all the tire size numbers mean, but I can certainly provide more detail or include a link to other info, if it will help answer your question(s).ThinkingAboutIt wrote:I know very little about changing tire sizes. Other than the sensor for tire pressure, are there any mechanical or operational issues with not using the specified tire size?
How much did it cost for the Toyo tires and Telsa rims?dividedhighw wrote:
For my EX, I ordered the Toyo "Observe G-02 plus" in a 225/60R17 size and got a good deal on these Tesla wheels from FastCo.
David
Traditional wisdom says that narrower (i.e. smaller sectional width) and taller (i.e. higher aspect ratio) tires are better for winter, because the vehicle weight is borne on smaller contact patches, giving more bite. But, you should consider that this is at the expense of more tire contact, which is actually preferred when the road surface is neither snowy nor icy.allthatjazz wrote:Which is a better match for the EX, and for winter 225/60R17, 215/55R17, 215/60R17, or 215/65R17? Found the answer at Tire Rack!
I'm still finalizing the cost of the tires since I'm getting them through a friend (with a little bartering).allthatjazz wrote:How much did it cost for the Toyo tires and Telsa rims?
