http://www.tirerack.com/tires/tires.jsp ... mpare1=yes
In the snow you should be worried about the tire touching the actual road, not being able to put down power.robomatic12 wrote:http://www.tirerack.com/winter/tech/tec ... techid=126
The only reason I suggest staying close to the TT rear's is because well, how are you going to put down TT power with 215's? The narrower tires do cut through deep snow better I agree.
