Winter tire help please =D
gounc14
Car: 1999 ATX Maxima
So the 240 should be sold relatively soon, and I've got a 99 Maxima now. The rear tires are almost completely bald and the front ones are on their way. I'm in the mountains of Virginia and will be using the car for a LOT of snowboarding trips, I'd go so far to say a metric asston. I need some help picking out some good tires for the mountains here, never had any experience with em before, thanks for the help guys.
Nismo_Freak
Car: 89 Nissan 240SX
You're gonna want a narrow tire with alot of sipes in the tread pattern.
http://www.tirerack.com/winter/tech/faqs.html - FAQ on winter tires
Notice the number of sipes in the tire (the smaller cuts in the tread); the resulting edges created help to grip in low traction situations (dirt, snow, etc.)
Snow tires also have alot better resistance to plasticizing (rubber turning hard, yeilding less traction) because of their lower operating temps.
gounc14
Hmmms I'm assuming its a bad idea to leave them on year round?
Q45tech
Snow/ice tires overheat and turn hard [permanently] above 50F ambient as internally they get above 100F.
Almost everyone needs; Summer, Fall and Spring [[all temperate season]], and winter/cold weather tires, IF they want the ultimate handling in each temperature situation. One hot summer is enough to fry All Season compounds making them worthless in winter.
aither
Car: Rock Climbing
Is the reverse true for summer tires used during winter (dry, no ice or snow)?
Nismo_Freak
aither wrote:Is the reverse true for summer tires used during winter (dry, no ice or snow)?
I don't think it will have as great as an effect since the tire will just be hard, not thermally decomposing lol.
It's kinda obvious when driving that true summer compounds in cold ambients because the first time you get on the throttle they act like baldy-no-grips
gounc14
Hmmms looks like I might have to get a hold of some steelies or stock rims to throw winter tires on then, thanks Alan for your help yet another time =D
Timeless240
Since proper winter tires such as my Bridgestone Blizzak WS-50's can be permanently damaged by a temperature of 50 deg F, how should we store these tires during the summer? Or are winter tires damaged by 100 deg F heat during storage? An un-airconditioned garage can easily exceed a temperature of 100 deg F on a summer day. Is that correct?
Q45tech
The internal temperature of a ice tires is much higher when deflecting [rolling] due to friction.
Year to year storage in a cool, dark place, wrapped in plastic to avoid ozone exposure.
People reuse them year after year but they are just progressively worse than when new.
keepingthe240
I'm going with tire chains or tire cables this winter.
