tooskerdo »
https://forums.nicoclub.com/tooskerdo-u60842.html
Tue Dec 11, 2007 9:45 am
Also put some mouse traps at the inner 4 sides of your tires. No need to explain why! Fill the tank up. ( I know it won't freeze) Run a heavier solution of antifreeze through it, then drian it before you drive it next summer. I would also put it up on jack stands so you dont get any flate spots, pull the battery. Heck, actually if i had to park it out side, i would remove the tires also and wrap the brakes to protect the from rusting up real bad over the winter. Just a few thoughts.
