I ordered these around the beginning of Dec, took a while to come but with the insane price some of these came out to be it was well worth it.
Special Thanks to Adam at z1auto for the ridiculous discount on the diff.
oem Nissan Final drive 4.083: I figured if I was never going to turbo the car this would be the next best thing, for me at least. I think this is the fd out of the Frontier truck. Just in case i do go with the f/i route i will keep the stock ring and pinion. Maybe even swap for the longer 3.3's found in the automatic Z's.
Quaife 1.5 limited slip, for the price Z1 offered (way less then 1k) why not. And it's the best match if you just so happen to have a Base model 350z. "Drop in installation"
JWT clutch/flywheel kit. stage 1. Originally I only intended to get one of these because my stock clutch is already starting to go, almost made it 100k miles. (currently at 96,xxx) Decided to go with this kit because of price and hearing nothing but positive reviews about them. Its basically an oem clutch with a stronger clamping force.
At Z1 auto they offer a recommended install kit for Z's with higher mileage. Basically comes with everything you need for a peace of mind lsd/final drive swap. Being passed 90k i decided to invest in the kit. Some of the stuff it comes with: ring gear bolts, new output shaft bearings and new output shaft seals.
And last but not least, license plate frames. (+32whp/23tq)
Yes, I have done a few writeups in the day. But i think i'll be leaving this one installation to the pros.
(In the DIY sticky, you can find a helpful thread that goes through the process of a home installation of the quaife lsd.)
End of line.
-soup
