same here! lol us California people don't have to worry about not driving our A/C in the winter because it just rains in Cali, no snow or anything (well most parts of Cali)adidas2go wrote: i think its a sports car
That's what I'm concerned about.....all the dirt and crap on the road durring the winter. I'm sure it will go in the snow ok as long as it's not too deep. But the Rock salt and Rock sand and Rock calcium and other chemicals to keep the water from freezing will raise hell with everything underneath. But I guess I'll try it this winter,,,see what happens. Hope I don't get too many dings or a chipped windshield. It's gonna be a long 4 months.SHIFT_COUPE wrote:I'll be driving the car in the winter using the stock tires. I'll be attempting to keep it at a minimum though. The car should be fine in the snow, I'm not really worried about it. I'm more concerned about it getting dirty
Nah, I think I'll leave her in there until I finish that venti Starbucks sitting in backSHIFT_COUPE wrote:Hey Eric! Take a hike buddy! Don't you have a girlfriend thats stuck in a trunk somewhere? Go get errrr
You could be god and I wouldn't care, Mr. "I am an engineer". I did lots of chemistry in university and think this is brilliant!LinkNuc wrote:Um, the "2 electrode" rust protection, hate to break it to ya, doesn't do anything, seriously there is a company out this way called CounterAct, believe me it dosent help in order for the "electro-rust protection" to work you'd to be constantly submerged in a conductive type medium, for the circuit of "protective electrons" to work. And even at that you'd need a lot more than 2 electrodes to make it effieciently work.
It is a viable option for marine type applications especially Salt Water based apps such as oil rigs.
Its called cathodic protection and its snake oil, trust me I'm an engineer.
Here's a nifty how it works: http://www.stoprust.com/pdf/15/CP-101-2007.pdf
Modified by LinkNuc at 1:15 PM 11/14/2007
Modified by LinkNuc at 1:19 PM 11/14/2007
What would you be reporting? That your car didn't rust. Wouldn't every other new Altima Coupe owner be able to report the same thing - since you wouldn't expect a car to begin rusting out until years after the purchase.mcheddadi wrote:
Anyways, I'm gonna report on this in the summer for results of the electronic rust proofing
Consider this an ongoing real life test.
Well the tires being insulators is what makes it so brilliant, this make the circuit complete, one positive electrode and another negative one at the back diagonally and then you have a closed circuit, they are applied on the unpainted body of the cart so you have your conductive material there that touches every other metallic part of the car, directly or indirectly. It doesn't have to be submerged in any liquid to work and you slow down any oxidation process!LinkNuc wrote:Sorry to get you all worked up, I'm just trying to protect people that bought into this snake oil (as I almost did). I wasn't bragging about being an engineer, I was just backing up my statement. If you are indeed a Chemist then this should be of no surprise to you.
Here's another excerpt of why:
"One has to understand the principle of CP to understand that the technique works by forcing a protective flow of electrons to the metal that needs protection. For this process to work, you need a complete electrical circuit to bring the electrons back. In the case of an outboard motor on a boat, the sea water completes the circuit. In the case of a bridge, the wet soil completes the circuit.
But in your car, the only way to complete the circuit on all the metal in your car is to drive into seawater or be buried in soil! There are various products on the market claiming to provide cathodic electrochemical protection to your car, just by injecting electrons into your metal work - but they don't work. Countries like Canada and the U.S.A. have actually got court orders to stop these products from being sold - simply because they don't work. In your car, there are lots of little nooks and crannies where dirt and/or water can collect. The rust happens not where the metal is dry, nor where the metal is wet - but at the interface between the wet and dry metal. So if you screwed a bunch of anodes right on the interface or one or two millimeters thereof, you would protect your car. But you would need thousands of these anodes over your car."
Or to think of it simply, you car is ON 4 TIRES!!! Last time I checked rubber is an insulator not a conductor...
Here ya go if you don't trust U.S. Engineers here's a test done in your own house.
http://ziebart.mb.ca/home/content/view/55/2/
Modified by LinkNuc at 8:59 AM 11/15/2007
