winshiled wiper arm? question/problem
s13redtaz
Car: 91' S13 Donated and gone..., 96' Toyota Avalon (DD), 92 coupe*SOLD*,92 5 speed Hatch
on my 91' coupe i ahve a problem with my windshield wipers/arms. the driver side works fine, but the passenger side only comes up halfway of what it normally should. im not sure of what to do about fixing it. any ideas?
oh it kinda hops real quick before it moves if that helps.thanks!
Defiant
Car: 1997 J30
If the driver's side is okay, it's probably a linkage problem. The jumping indicated a binding situation. Pull the cowl trim and see what socket got dropped down in there to get in the way, or to knock the linkage ajar on the passenger side.
KFL
Car: S14
What above stated..also the nut on the wiper arm its covered up if it gets loose then it will result in slack=not going up all the way.
s13redtaz
thanks! ill check it out tomorrow morning.
