winshield washer nozzles
Zak427
Car: 93 2+2 Twin Turbo
anyone know where i can get a good strong set. my stock one's are corroded and clogging up. plus even new they are weak. any good aftermarket stuff out there. besides the ones that light up?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
if the new ones are weak maybe the problem si in the pump!? as far as I know the squirters would be a pretty generic replacement part unless you wanted one of the ricetastic light up models like you see on the pimped out accords and cavaliers
MaximA32
Try your local dealer. They'll be aboe to get ahold of that part and if they don't have it in stock, they should be able to order it.
gpelite
Car: 1990 300zx TT
if you remove them and have them soak in CLR or a Lime n rust remover that usually is a cheap way to clear them out
Otherwise any auto store has generic replacements, depends on what you prefer
