scotty-2-forty »
https://forums.nicoclub.com/scotty-2-forty-u1049.html
Fri Mar 12, 2010 7:55 am
After the car is warmed up, or after driving it and it makes that sound, park the car and have someone gas it a bit with their foot on the brake (putting load on it). Open the hood and check to see where the sound is coming from. Alternators can whine when they are going bad. Have the alternator checked out, and/or perform a voltage check. Turbo bearings can do this too ... any exhaust smoke??? Since you already ruled out belts, it's not the power steering. Is the temperature okay? Check the water pump. Are you certain it's from the front (sounds can echo or carry) ... check the fuel pump too.
Good luck with it; I know first hand this stuff can drive you batty!
