Klits562 »
https://forums.nicoclub.com/klits562-u133972.html
Sun Dec 06, 2009 2:30 pm
does the motor work and the wipers just dont move or does nothing at all work?replace the fuses for it (idk were they are but im sure you can find them). If that doesnt work use a test light to see if the motor is getting power if its not then it could be a damaged wire or the switch on your steering column that has the wiper stick on it might be busted. Try replacing that they're cheap at the junkyard. Now if the motor is getting power but not working then replace the motorgood luck
