When you activate your windshield wipers, electricity is sent to the wiper motor, which in turn activates the linkage, and then operates the wiper arm to move the wiper blades across the windshield. The entire system is controlled by a windshield wiper module. Some mechanics refer to the wiper module as the wiper governor module. It is located underneath the dashboard, above the brake and accelerator pedal, and is responsible for the complete operation of the windshield wiper system. This device controls intermittent wiper operation, high/low speed wiping, and obviously turns the wipers on or off.
The windshield wiper module is pretty well protected from the outside elements; however, it is an electronic component and is subject to failure over time.
YesMaximus099 wrote: ↑Thu Jul 12, 2018 1:59 pmDo you have to pay for this diagnostic even if they refuse to do the work?
They haven't made a decision yet
That is pathetic! They charge you for a "diagnosis" which they really didn't even do because they just want to throw the parts canon at it. Well we don't know what the problem is so first we will replace this then that!wchunter wrote: ↑Fri Jul 13, 2018 5:33 amThe Technician started a Tech Line since no-one at the Dealer had seen or heard of a vehicle exhibiting these symptoms. After sitting at the dealer for over 3 hours waiting on a verdict, the conclusion from the technicians on the Tech Line was this:
They recommended replacing the wiper motor to start and then retest the auto to see if the symptoms were corrected, if problem persists then replace Body Control Module. Worst case scenario is $1335.72 for parts and labor. OUCH!!!
The technician did disconnect the battery terminals and allow the car to sit for a while then reconnected and the wipers did work correctly during a short initial test, but he caution me that this properly didn't correct the problem and not to try the wipers unless we needed to (rain). If Nissan decline to cover the cost of the repair, I'll submit a customer complaint (not that this would do any good) and then if the problem persists, I'll order a wiper motor form Nissan PartsPlus, or somewhere where I can get a OEM motor at a decent cost and have someone local do the repair for a fraction of the Dealer charge.
First thing first, 9hrs??? Are you crazy to sit in a dealership for 9hrs? Didn't they at least offer you a ride or a loaner while the car was in service?wchunter wrote: ↑Thu Aug 09, 2018 2:03 pmI sat at the dealership for 9hrs yesterday while they were working on the car. Then new BCM did not fix the problem. Nissan Tech line was supposed to do a video call today with suggestions/ possible remedy, but as of 4:00est, they haven't called and Nissan tech line hasn't responded to 4 emails sent by the technician today. They even replaced the fuse box yesterday, but that didn't help either.
I'm a paraplegic, they didn't have a loaner with hand controls. My wife and son had to drive the 1.5 hrs to pick me up. Good news is the car is fixed. After all was said and done, they "discovered" a wire had been damaged by a rodent and once the wire was repaired and a new BCM installed, the problem is fixed and my wife is back on the road.datechboss101 wrote: ↑Thu Aug 09, 2018 2:22 pmFirst thing first, 9hrs??? Are you crazy to sit in a dealership for 9hrs? Didn't they at least offer you a ride or a loaner while the car was in service?wchunter wrote: ↑Thu Aug 09, 2018 2:03 pmI sat at the dealership for 9hrs yesterday while they were working on the car. Then new BCM did not fix the problem. Nissan Tech line was supposed to do a video call today with suggestions/ possible remedy, but as of 4:00est, they haven't called and Nissan tech line hasn't responded to 4 emails sent by the technician today. They even replaced the fuse box yesterday, but that didn't help either.
Now, they replaced that BCM and fuse box and still that problem consists, which they basically threw parts to "try" to fix. Try an independent mechanic, or if you have free time, PM me for the FSM, since I have a copy, and you can at least try to narrow down the issue.
