awdjdmtalon wrote:Could have one of two things going on. First, you should take a VERY SMALL stright pin and clear the nozzel jets, and see if it squirts. Second, if still nothing, listen for the motor to run. Then check the lines for leakage.
Ok 3 thing. If 1 and 2 don't work. remove the hose from the pump motor,and from the nozzle's. The take compressed air and back purge the lines.
Number 1 fixed it! Thanks!!!
I was unsure of how to reposition and clear the jets, but your suggestion was perfect. I got a pin and stuck it in the jet, then swiveled it around with the hopes of dislodging any crustys.
I still have one small problem, but I'll need a helper to figure it out. I think one of the stationary jets squirts over my hood on the return stroke. I poked the pin in there to clear it, but I'm not exactly sure which one it is. I adjusted all of the moveable ones and none of them are the culprit.
Thanks again Jerry!
