windshield washers suck !
wangless
Car: '02 MBP WRX
hey... is there anyway to clean my windshield washers ?... the driver's side works just fine... but the passengers... one of the two nozzles doesnt work... and the other one shoots way to high... its high enough to go on to the top of my car... what the heck... and the back... it doesnt even spray... it just leaks out of my nozzles... anyone have suggestions ?... or even those LED ones... but what about the back one ?... do they make one for those ?
NiSilS14
Car: 95 240sx
maybe you can go to the junkyard and find a set off a different car
Infamous
you can get the LED ones:oface, just snip the power wires off them....just as precautionary
Tai Mai Shu
Use some CLR cleaner, its just gummed up, or maybe try using a neddle?
Aries
Car: LT1 240SS
I used a needle on mine.Also, CLR or windex run through them can clean it out fairly well.
erich
The nozzles are adjustable. They are a ***** to align correctly. I used a tiny piece of music wire to clean/aligh mine. Put the wire in the nozzle a move it around a bit. If you push the wire sideways the nozzle will move that way. It's just tough to get the rotation correct .
1dollar240
The ricer style led ones are also "high pressure". It would be kinda cool if someone made high pressure ones without led's on them. I just want some good water flow!
wangless
Car: '02 MBP WRX
high pressure ?.... cool... i wonder if i could buy them and not just hook up the lights... and paint them black... haha... kinda defeats the purpose of buying them, but at least ill have high pressure...
but what do i do with the one thats on my top rear ?... or do they use the same kind of washers ?
Cookie
Not sure if you have them in the states, but peugeot 406 washer jets are a good upgrade.
C.
sultan
i used a pin on mine, and then blew on the end of washer fluid hose and some thick sludge stuff came out of the nozzles all over my windshield. come to think of it, antifreeze tastes much better than windshield washer crap.
Silvia007
Car: 93 Nissan 240SX SE Fastback
replace your washer pump with TWO Walbro Fuel PUMPS!!! 85 bucks on ebay baby. May require some modification.
Cyberkreig
Car: 1993 Nissan 240SX SR
haha Walbro pumps... *THEN* Piss in the fluid reserve, turn the nossles sideways and cruze around walmart parking lot.. or people with open windows at stoplights..
