Windshield washer problem?
benavidesjr
Car: 1990 240sx
I recently bought a 90 240sx from a friend and am going to fix the minor problems it has and start fixing it up. one current problem is " Washer fluid will not come out of the front nozzles, it will however come out the back nozzle for the rear wiper. The resovoir is full of washer fluid. I disconnected the rubber hose from the front two nozzles and tried and nothing came out, not even a drop. Any suggestions? Plugged lines? Bad pump? Thanks in advance.
NISTECH
possibly a bad pump the front pump is different then the rear pump. If you dont care about haveing the back washer just swap the hoses between the motors, just remember the rear washer switch will then be for the front window.
