Wally26 »
https://forums.nicoclub.com/wally26-u190371.html
Fri Mar 02, 2012 7:19 am
Has anyone had this issue? The stream is strong, but fluid is hitting the drivers side arm, so the windshield is only getting what bounces off. It seems to have my dealer baffled. First they said that the blades I put on were too high, so I told him that the ones that were on before did the same thing, which were from them btw. He then tried the factory blades, and they worked. They tried replacing the washer nozzles to the newer ones, that didn't work either. I'm not buying that the only fix for this is to use the factory low prof blades, but is it?
On a good note, they did address every other 08 EX35 issue..oh, except for the elusive high freq directional ring around 2000rpm, which I guess I'll live with until they come up with a fix, not a guess.
Replaced were... The fuel pump, rear hatch struts, steering rack, roof rails, and the serpentine belt..whats up the Infinti belts going so soon? Sqeal started around 18,000 miles on start up.
