philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.html
Sun Mar 02, 2008 4:04 am
With the amount of road salt used in Southern Ontario, washer fluid is not just a convenience it's a matter of life and death! I go through 6-8 jugs of fluid every winter.
Msdarkdiva,
Unfortunately the FSM does not indicate if US models come with the wiring.If it's there, there should be an oval shaped plug with 2 wires (white and black) located near the washer fluid tank. You can access the tank by removing the plastic fender liner on the passenger side.
Assuming the plug is there and the warning lamp is in place, it would be a simple matter of replacing the washer fluid bottle with the unit that includes the level switch.
BTW, my Rogue is an SL FWD. No options. The low washer fluid indication appears to be standard on Canadian models. Perhaps others who have bought thier Rogue's in Canada can confirm this. It would be very bizarre if it wasn't since every Nissan I've owned had the low fluid indication.
