imnprsd »
https://forums.nicoclub.com/imnprsd-u304061.html
Tue Jan 25, 2022 11:00 pm
OP UPDATE: Today I fixed the dash light problem by disconnecting the washer fluid tank sensor wire connector.
It was not hard to get to and only took 30 minutes. Just remove the skid covers on the passenger side, between the wheel well and the engine skid cover. You don't have to remove the fender skirt. Just wedge a 1" flash light or other object to expose the bottom of the washer tank and then pop out the electrical connector. Pull the electrical connector apart and then seal it with electrical tape. This will permanently "open" the circuit and your dash light will go off. Of course your Washer Dummy Light will never come on again, but who cares! Just be sure you keep fluid in your tank so you don't overheat the wiper pump motor.
Note: Disabling the power to the sensor is easy, but removing the sensor it self (Part #28911CG000) is a lot more work, because you have to gain more access to this area. The sensor can still be bought for $135 list, but my Infiniti Dealer quoted me $80. I would have ordered one, but I did not want to spend a lot time removing the bumper cover. So this repair did not cost me anything and now my washer light on my dash is "off" for good. No worries. I'm satisfied.
- 2004 FX45 Wiper Tank & Washer Motor.jpg (51.55 KiB) Viewed 33922 times
- 2003-8 FX Washer Fluid Level Sensor.jpg (21.42 KiB) Viewed 33922 times
