Windshield Wash Issue
nkawall
Car: 93'Infiniti J30 & 09 Altima Coupe 2.5
Hey just today my windshield wash hasnt been spraying out of any of the nozzles when i pull back my lever...what could this be?...the pump?
gr8scott72
Car: 1994 Infiniti J30t
nkawall wrote:Hey just today my windshield wash hasnt been spraying out of any of the nozzles when i pull back my lever...what could this be?...the pump?
You are the one there beside your car. Pull the triger and listen. What do you hear? That would be the first thing to do.
naladude911
Car: 2001 Infiniti QX4
lol is it empty?
yodawill2000
Car: 94 Infiniti J30
Mine hasn't worked since I bought the car ..Need to fork up 15 bucks for a pump that takes 10 minutes to swap.
Defiant
Car: 1997 J30
My feed tube got nibbled by a rodent. A stinking, rancid, buck-toothed, over-breeding rodent.
nkawall
lol yeah this morning was pretty warm outside...amazingly..and i took a look and i heard the pump working and found the hose was disconnected right at the top of the fender on the right side and it was leaking out ...reconnected the hose and it was good to go
driverdriver
Car: NICO's longtime resident Canuck!!!
nkawall wrote:lol yeah this morning was pretty warm outside...amazingly..and i took a look and i heard the pump working and found the hose was disconnected right at the top of the fender on the right side and it was leaking out ...reconnected the hose and it was good to go
That is such a common issue up here, especially with expansion and contraction from the cold to sudden hot and vice versa. The hose simply disconnects.
96J30
Car: 1996 Infiniti J30
Does anyone know of a different nozzle that fits the J? I did this when I had my Civic, swapped in Accord nozzles (they spray in a wide fan rather than two little jets, sprays the windshield a lot better) Are there any that fit the J that spray like that?
gr8scott72
96J30 wrote:Does anyone know of a different nozzle that fits the J? I did this when I had my Civic, swapped in Accord nozzles (they spray in a wide fan rather than two little jets, sprays the windshield a lot better) Are there any that fit the J that spray like that?
Ask naladude. He probably knows of a car only sold in Japan that does that.
