amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Wed Jul 11, 2018 6:15 pm
One thing the glass guys won't tell you.............you want NEW glass if at all possible, you can get used for $75 all day long from the yards but the issue is that the removal process degrades the glass quality and life by slightly chipping the edges getting them out, then the glass being tempered later cracks at the chip marks which are stress risers. Not all will fail but well over 50% of them can in less than a year and often in summer when it gets really hot or really cold day in winter, the glass expansion or contraction seeks the riser to crack. The slightest chip on the edge can do it.
I picked up on that pretty quick doing body repair. Some few like some Fords when they were trying to streamline the glass install process on the assembly lines are mounted in a rubber gasket and no glue or tar rope, those can come out very easily used by cutting the rubber away from the glass edge to in effect have a still new one.
Now they glue them in with kick-ss polyurethane that if they cut them out in the yards will likely break most of them right off the bat, that stuff is a killer sealant but pretty hard to get those out safely.
