Rockhound »
https://forums.nicoclub.com/rockhound-u65977.html
Tue Oct 02, 2007 4:33 am
Well, it all depends upon weather conditions and how the temperature inside your car compares to the temperature outside. I'm guessing that the humidity is pretty high in your area, too, which makes the incoming air behave similar to breathing on a cold windowpane. Just make sure your climate control is set to intake outside air and leave the A/C on. You can run the A/C on whatever temperature you like without any problems - you can run it full hot in the winter time with the A/C on, just to dehumidify the air.
That said, I have noticed some cars fog worse than others. My first car (93 Sentra) fogged up like crazy, but my current car rarely does so (G20). I also haven't encountered any fogging in the Versa yet, although weather conditions haven't been conducive around here just yet. I'm not sure why one car would fog worse than another, other than perhaps the design of air intake ducts and how much they are affected by the heat of the engine and such.
