Windows, seat dont work, HELP!!!
q45VIP
Car: 94' Q45t
So this morning I go to turn my 94' Q on and, nothing.Battery is dead. Bought a new one , fired right up.
BUt now my windows do not work, the controls for the seats dont work,the "airbag " light flashes all the time , remote does not work ,and when I open the door the security light flashes faster than usual.
The thelescopic controls work fine manually , memory does not work.
I tried to re-set it with the steps from another tread :
Open driver doorTurn key to on positionTurn back all the way but, dont remove.Wait one min. Open door.
It didnt work .
I need help guys!!!Thanks a bunch!
JedCoop
Car: 94 Q45t w/TCS, 92 Q45 w/TCS, 91 Q45 touring (RIP)
Try the LAN troubleshooting directions in the FSM Body Electrical section.I sent you an email with this section of the FSM.
q45VIP
Car: 94' Q45t
Thanks .But, for some reason I cant open the file
I got the FSM in my computer and was reading through the LAN troubleshooting part but, I got lost. I dont know jack about electrical.
Ill give it another try.Thanks!!!
EQwhipD
Car: 1994 Q45 (Totalled)/ 1994 Q45a (SOLD) / 1990 Z32TT
If your seats and locks option doesnt work...most likely water got into your window and shorted out your master control switch. Pretty easy DIY, remember in order to take the door panel off, you need to slip the arm rest towards the rear of the car; to where you will see the screws that hold the panel to the door. To make sure it is your Master Control Switch, see if your windows work, but your locks and seat control doesn't. This happened to me.
q45VIP
Car: 94' Q45t
Its not just the windows .Its got all the simptoms of the "Fail Safe System"
Does anyone know of a quick fix to this problem?
Thanks.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Sometimes one of the main fuses will fail, especially if you accidentally mishandle the battery or something like that... CHeck the main fuses
elwesso
2007 BMW M Coupe
heres a thread to check
zerothread?id=96274
q45VIP
Car: 94' Q45t
Thanks Elwesso.Ill give it a try.
q45VIP
Car: 94' Q45t
Problem fixed.
It was very simple.
What happend was that about 2 weeks ago my rear driver side regulator went out , so I took all the guts out (regulator,motor) and did not put it back on.A week and a half went by without a problem , then all of a suddenmy battery went dead , and the problems started.No power windows, locks,remote unit, power seats.
It turns out the BCM was not getting any signal from the motor/regulator I removed So , this morning I hooked the window motor/regulator back up and everything works just fine.
Just wanted to say thanks to everyone.Hopefuly this will help somebody else.
elwesso
2007 BMW M Coupe
Glad it was easy... we are blessed that the Q45 doesnt have more electrical problems that are serious.... makes me glad i down own an old german car!
audtatious
elwesso wrote:makes me glad i down own an old german car!
The older German cars are not that bad. It's the new ones that are falling apart....
