Windows roll up really slow.
unknown007
Car: White 1993 Q45 (G50)
Motor replacement needed possibly?
Trumpkin
Car: 1995 G50
All of your windows are slow? Check your alt. output. Why would all of your window motors go at once. Please be more specific.
unknown007
They have been slow since I got the car.One rear one goes fast, other okay,drive so so,passenger really slow.Has nothing to do with my alternator I hope I mean everything else works fine and opens fine.I'm just guessing it could be the motors worn out I mean I have a 93 pretty old don't you think?
goody90q45
Car: 1992 Infiniti Q45 (sold)
All the dirt and dust that blows into your car's interior for the past 18 years also makes its way behind the door panels and starts to gum up the window regulator assembly. If you take each one out you'll find them to be gummed up with dirt filled grease. There's probably nothing wrong with the motors but the regulators will need a good cleaning. You may find the one that runs really slow has a broken plastic retainer on the end of one of the cables.
Take each window regulator/motor out as an assembly, unbolt the motor from the regulator and give the regulator and its cables a good cleaning (toothbrush, simple green, brake parts cleaner) and regreasing (lithium?). When you're done the sliding bar that holds the window should move manually with little effort and reeve the cable smoothly on its drum.
unknown007
does the assembly come out the top or panel side?i took an 89 accord one but i couldn't take it out through neither side.thanks mike your dope.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
unknown007 wrote:thanks mike your dope.
I bet Mike would like his dope back!
goody90q45
unknown007 wrote:........thanks mike your dope.
What did I do to become a dope?
What's wrong with b****en, cool or groovy?
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
your not a dope, your dope
unknown007
hahaha how about you boss status hahaha
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
mxr662 wrote:your not a dope, your dope
Mike sure has a lot of gauge to go around!
unknown007
Mike my steering wheel and seat move now alone.I dunno how it just does and I think that's dope!!!Fa' sho I'm wet now. It does get annoying though cause I was trying to eat a burger and put my key in to turn the radio on and it move squishing my leg lol.
