windows Auto-up feature not working
mxquattro
I cant seem to get my auto up feature working on any of the windows. Ive tried it only from the drivers switches, I suppose I should try it from the individual doors.
The one touch down works fine, but not the up. Is it maybe some setting in the config i need to find?
biggie
Unhook you battery lately? That usually resets them.
Roll down window, roll up window all the way and then keep the button held up for 10 seconds after it stops. That should reset it. Would have to do it for each window.
mxquattro
Yes, in fact I did! Thanks for that, Ill give it a try :)
joe603
Car: 2014 Durango R/T
That should work...I've had to do it before.
Tim30250
Car: 2009 G37 Journey Premium/Nav/Cargo Net!!! 2002 330Ci - Supercharged
Same here, always happens after the battery is disconnected. The 10 second trick fixes it every time tho..
audtatious
Once it didn't fix it for me and I had to disconnect the battery again and it worked.
speedemn
Car: 2009 Infiniti G37x
biggie wrote:
Fri Mar 16, 2012 12:18 pm
This worked perfectly. Thank you!
