mikesd1980https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113Windows - Auto up do not work on any of the windowsMon Sep 02, 2013 10:01 am
Postby
mikesd1980 »
https://forums.nicoclub.com/mikesd1980-u224636.htmlMon Sep 02, 2013 10:01 am
Been lurking for a while now. I have a 07 M35x. The auto up stopped working from the drivers side for all windows. I havent tried each individual door window switch. Is there something I can check for to get this feature to work again? Thanks for any advice.
Postby
svard75 »
https://forums.nicoclub.com/svard75-u133637.htmlMon Sep 02, 2013 10:30 am
Open each window half way then use the drivers switch hold it for a good 3 seconds after the window is all the way up then release. Do this for each window including the sunroof. Did you replace the battery recently or did it completely drain?
Car: 08 Infiniiti M35 black loaded custom VIPDOUT 08 Infiniiti G35 S sold 92k miles 08 Infiniiti M45 S sold 78k miles 07 Infiniiti M35 traded 53k miles 95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Postby
The Bodyguard »
https://forums.nicoclub.com/the-bodyguard-u172738.htmlTue Sep 03, 2013 9:41 pm
Extremely common happens every time a battery is changed!! Actually should have found it under the search function but nevertheless... Do as the first reply instructed you!!
