Window wont go up!
IvanS13
Car: *** & Titties
****! Its snowing and its like 30 degrees around here in DC and my passanger window wont go up. I think it's off the track. Any ideas? I tried pushing it up and no luck...
topless@vabeach
Car: Electronics, anything that has trons in it.
Did you try the button in front of your window switch, right by your window controls on your left door arm rest? Push that once and try the window again.
piratepete
Is the motor making noises but the window won't go up? It happend to my driver side window a couple of days ago. Turned out the rubber donut thing between two gears was torn. Kinda hard to expalin. Just start taking it all apart and you'll find the problem eventually.
KSee777
could be that the cables are off track. Mine was all tangled up when my window didn't work.
1991240xs
try directly hooking a 12 volt battery up to the wires for your motor(taking the door panel off)..i've had to do that when i have a problem with my windows and it starts to rain..
