tollboothwilley »
https://forums.nicoclub.com/tollboothwilley-u74535.html
Mon Jan 07, 2008 8:04 am
a suitable tool would be a paper clip/pin or whatever you can find that will fit in. Most of the time, if you just use a pin, you will find that the hole slightly gummed up and by poking in and out of each hole a few times that it was just dirty. You'll loosen up and clinging dirt and may not need an adjustment.
to adjust, just move it around while the pin is in the hole to where you think is best.
