goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Sun Feb 03, 2008 8:16 am
It sounds like the regulator you bought and installed has problems with the cable or is this in a different door?
At this point you've removed and reinstalled a window regulator at least once so you're an expert like the rest of us. The second time around won't take you but a few minutes. I've sold 9 or 10 of these and what I do to determine if it's a saleable part is to remove the assembly from the door, remove the motor (3 screws), clean and lube the entire assembly-cable, slider, tracks, cable drum, etc.. Get all the dirt out, it will clean up like a new part. Be generous with the lithium grease.
When your done you should be able to move the sliding bar that holds the window freely up and down the track and there should be no binding. If the cable is frayed it's probably not feeding in and out of the tracks and the problem will just get worse. On the other hand cleaning up the cable drum, cable and tracks might work great and bring it back to life, and your hour investment will have saved you $150. Let us know what you find.
