Ok, my passanger side window is stuck (moves about a inch down) in the up position. Well, since I've never done anything on a car (I'm just now starting to get into this kinda stuff) I thought I'd give it a go and fix it solo. Well, after removing the door panel ('92 240sx) I realized that the reason it was stuck was because the track the window slides on must be bent. Not feeling adventurous enough to remove the entire door I just decided I'd find a shop to do it. Now, my question is what kind of shop am I looking for? I've called body shops and the conversation usually goes like this;Me-"Hello, I have a '92 240sx with <problem>, can you fix this?"Them-"Ye.s"Me-"Can you give me a rough estimate of how much it will cost?"Them-"Uhh, well, you will have to bring it into the shop because I'm not sure what you are talking about."Me-"Ok, great. Thanks" *click*So, maybe I am just having bad luck with these people or something or maybe I am just looking in the wrong place. I live in Tampa, Fl so if any of you happen to live here and/or know a place I could take it. Let me know.
Thanks.
