window track busted
studiomtn
hey just wondering if the window track on a 96 240sx replaceable or fixable. mine busted and got bent and some bearings busted. can nissan fix this? is there any alternatives? thanks
-mike
speeds8r
Car: 1989 240 hatch / 1991 240 coupe w/96 motor 70k
The track is easily replaced. Any Nissan dealer can do it but if you can do it yourself just go to a junkyard. All you need is your ratchet, phillips srewdriver and a few sockets 10mm to 13mm and you should be ok.It's really not a hard job at alll on these. GM products are a PITA and you have to drill out the rivets and replace etc. These are a breeze on a 240 so if your able try it yourself and save the cash !!
