Window rubber mentioned in "restoring" article?
Discussion forum for the venerable 510, and its non-US counterparts, the Datsun 1600 and Bluebird.
ByStickel
Car: 1972 Datsun 510 2dr
1972 Datsun 510 wagon
1972 Datsun 510 4dr
1978 Datsun 620 KC
I stumbled upon the articles about restoring the '68 sedan and was especially interested in the parts about replacing the weatherstripping. Greg talked about a nice solution for replacing the external window squeegies, but I can't see any reference to where that rubber came from.
Does anybody know where they got the proper l-shaped rubber?
I tried to find contact for Greg, but it just sends me to his other articles.
Thanks, in advance.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
If I'm not mistaken, that would be our fearless leader AZhitman. I'll rattle his cage and see if he'll pop in here with a reply.
ByStickel
1972 Datsun 510 4dr
1978 Datsun 620 KC
Thanks, Rogue.
Is there no way to send a message to 'Greg"?
Hey BS! :)
IIRC, I ordered it through Steele Rubber. http://www.steelerubber.com/peel-n-stic ... upward-lip
ByStickel
1972 Datsun 510 4dr
1978 Datsun 620 KC
Hitman, Thank you!
I was looking at mine today and even think I can cut off the OE staples and use the existing holes, even if I have to make my own staples. Not sure if the rubber has the right dims for that, but I'll check.
All my Datsuns thank you.
You bet. I think I documented the process pretty well, but if not, we can discuss. Half the fun of restoration is figuring out a different way to do things. :)
MikeRL411
Car: 1997 Infiniti J30T
1967 Datsun RL411
Check Steel Rubber site for just released newly made windscreen and rear window rubber with/without chrome insert capability. Steel made them from factory dimensions so should fit well.
Return to “Datsun 510 / Bluebird”
