window relay and emergency flasher location?
roberts0690
Car: 2002 Q45
My rear window goes up and then right back down.It wont stay up regardless of witch switch we use.Also my emergency flashers dont work.All of my turn signals work fine.Any ideas.Tried the search option and it blows.
djwarner
Car: 1971 240Z Series I
2006 350Z
I have an 02 Q45 and an 08 Mustang. Both have one touch power windows. Built into the design is an automatic reverse if it senses something caught in the window as it closes (ie your daughter's neck). This type of design also has to know when the window is actually closed so it can snug up the window and stop.
From what you describe, the closed sensor (switch) is not sending a signal and when the glass hits the jam, it is executing an emergency reverse.
As for both your flasher and window problems, consult the FSM.
Q451990
The FSM (factory service manual) is available at www.nicoclub.com/FSM/
Heath
