GseaQ wrote:Now for the BIG question. I bought some stuff from xr4racer 10,000 mile parts car. Will regulators and motors from a '90-'93 fit a '94-'96?
All regulators and window motors are interchangeable for all 90-96 Q's. The regulator is different in each door but both motors on the PS (front and rear) are the same and ditto for both motors on the DS.
Chances are pretty good it's just the regulators that are broken since the motors are pretty stout. I've removed 12 assemblies, a few with broken regulators, and every motor worked fine. Pull the regulator from each door and what you'll probably find is the plastic piece that attaches the cable assembly to the sliding mechanism is cracked or broken off, or, the cable has frayed and is not wrapping on the drum properly.
