louiegz »
https://forums.nicoclub.com/louiegz-u10925.html
Sat Apr 23, 2005 7:44 am
I replaced the driver's regulator about 2 months ago. When I tighten down the screws, I tested the window before I put the door panel on. The glass slowed down, just as you say. I noticed the glass didn't go all the way up. The regulator has play when the screws are loose. Put the regulator in the full up position and pull the glass up until it stops and tighten the screws. I guess when I did that, it aligned the glass better, hence making the window work up to normal speed. It worked for me. I hope you haven't put your door panel on.
