moneil4 wrote:stopped completely
Power Lock schematics
Power window schematics
From the looks of the two diagrams it has to do with the BCM (Body Control Module) but it also could have something to do with the CPU in the window switches, although if all of them are dead it's likely the BCM. Someone on here mentioned an issue with a leaking windshield where water would enter the BCM chamber and cause the connections to corrode. Might be worthwhile checking the BCM out.
Here is how to remove and check your BCM
EDIT: Sorry about that, my google pictures got moved somewhere.
