im not familiar with 97's but it sounds like it might be the window track, that is if 97's work on a trackmrgrape wrote:Okay i have a 97 240sx and window problems.my passenger window works perfectly fine. When i click on the switch for drivers side it makes a ween ween noise but doesnt move.When I was getting my car painted, the owner told me after the job was done that he looked into it for free and it was either the regulator or switch but probably regulator but NOT the motor.
Knowing that I got a used regulator off the same model car and went to a mobile window repair guy and when he took it off he said it was the motor and that my regulator was totally fine.
Now im stumbled. 2 shops saying contradictory things and Ive already spent like $100 trying to figure out the real problem.
I am considering tomorrow to take it to a shop and PAY AGAIN for just DIAGNOSE and then REPAIR and prob PART which is going to cost me a lot of money.
The motor makes a noise for sure..its not dead as it respons to when i click on switch, but the window just doesnt go up or down =[
Help please
check and see if this might help!http://www.s-chassis.com/forum...46462mrgrape wrote:its the same like this http://www.youtube.com/watch?v=iMQ8CYwmIqoit goes down half a**, and doesnt go up at all but makes that ween ween noise.
Yeah, it really sounds like its you trackJ14cm7 wrote:Hey i had a window motor go out on mine. Dont take it to a shop and dont fix anything unless you KNOW what the problem is. Take the door panel off your self it takes five min and diagnose the problem. Its not your switch cause something is responding. After you take your door panel off disconect your window motor wire (on mine it was blue and green i think) and hook it up to a hot and a ground off your battery if the window works fine then its your regulator. If it goes up and down but stops then its your track. if it doesnt work at all its your motor. You will be able to fix it either way.
how do i hook it up to a hot and a ground off my battery???how do i fix a window track...J14cm7 wrote:Hey i had a window motor go out on mine. Dont take it to a shop and dont fix anything unless you KNOW what the problem is. Take the door panel off your self it takes five min and diagnose the problem. Its not your switch cause something is responding. After you take your door panel off disconect your window motor wire (on mine it was blue and green i think) and hook it up to a hot and a ground off your battery if the window works fine then its your regulator. If it goes up and down but stops then its your track. if it doesnt work at all its your motor. You will be able to fix it either way.
If you are really not car savvy then take it to the dealer cause it takes patients and a few different attempts to get everything back in perfect working order. I doubt your track bent. I know it didnt rust. I really dont know what could have gone wrong with your track unless it just jumped the track. Anyway the shop is gonna charge you an arm and a leg. If you do it yourself just be aware that your 240 not only does the window go up and down but when it comes up it also comes in towards the car so it can tuck up under the door frame. this takes alot of adjustment and trial and error to get right. Its def doable if you have the patients though.mrgrape wrote:
i wish i can just take it to a shop.....
the amp is in switch for 96-98sx moneypit wrote:I thought i had switch problem with my car ,but it ended up being the power window amp.The amp is bolted to the door (a small rectangular box) it is not in the switch itself.The amp is much cheaper than the switch.
Dude, where is the FSM for the 95 and up 240 located for free!!! Ive searched to no avail!!J14cm7 wrote:look at the FSM (factory service manual). Its free online and on this site if you just search. it has a troubleshooting section for this exact problem and you should be able to figure this out using that. The reason i doubt its the switch is because you are getting some type of response when you switch the window. but if it went up and down freely when you applied direct power to it then i dont know what to tell you. if it was the amp it wouldnt work at all.
Literally type S14 FSM into the search engine and it will come up with a list of every 240 fsm there is.obg3506 wrote:
When i took it to the japanese auto, they did that hooking up motor to battery, and the motor went up and down over the regulator(we already had regulator taken off, and window all the way down when we did this)By looking at the diagnose chart, i followed it and it said if drivers side doesnt go up or down it is the power main switch..the japanese auto i took it today said the motor did not have enough power to go up......but it didnt even have enough to go down.J14cm7 wrote:
These shops are insane. They are making you spend a bunch of money you dont need to spend. When you pay 100 dollars for a new motor its gonna be your amp is bad. Diagnose the problem and then spend the money. Hook the motor up to your battery directly and see what the window does. If it goes up and down fine then thats not the problem. We knew it wasnt the switch cause you were getting signal. Its gotta be the track or some VERY unusual wiring issue. Either way you can diagnose this using the FSM or wasting time and alot of money on these shops.
I dont usually do this but in my personnal opinion your window jumped the track and is f'ed up. In my experience motors either work or they dont.
no to that precise question.When we tested the motor to the battery...the motor was off the car as well as regulator....the motor and the assembly went up and down on the regulator assembly.J14cm7 wrote:Ok so just tell me have you SEEN the window go up and down when they hooked it up to direct power?
