5hiftg3ar »
https://forums.nicoclub.com/5hiftg3ar-u42763.html
Thu May 31, 2007 5:32 pm
ok so ive done my share of searching and i think ive come up with some possible solutions: first of all, the problem that im having is that my window on my drivers side is stuck halfway down and wont budge either way. i suspect that its most likely the motor because ive been having this probmlem for weeks now and whenever that would happen i would just bang on the door and hold the switch down and that would typically solve the problem. when i tried that today, my window went halfway down and just stopped...tried pounding it and nothing happened...i still hear the clicking noise when i push and pull the switch for the window to go up and down so i know that the wiring is still good which is why im suspecting the motor...am i right? if so, i read that i might be able to hook up a car battery to two wires and tap those onto the wires leading to my window motor and that could possibley solve my problem...is this true? im also trying to see if theres any way i can manually roll up my window so that it wont be vulnerable to theft and what not while i look for a new motor...got any suggestions? oh and does it matter what kind of wires i use? and where exactly am i tapping the wires to? thnx in advance!
