Window Porblems
razah9
So now when I hit the passenger side window button I hear a clickingsound coming from the passenger window's button... Sometimes thewindow would go down 3 inches only to shoot right back up...
I got the gold extended warranty with my coupe so I guess just havethem fix it huh?
Could have sworn someone else had this problem but I couldn't findthe thread.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
I believe what you read was that the auto window up feature didn't work on some vehicles. For some silly reason, Nissan programmed the windows this way when the car's battery is disconnected. For that problem, you simply roll the window down over half way, then roll it back up, continuing to hold the window up button for 3 seconds after it stops. This resets the auto up feature.
But for your problem, I have no idea. Try the above method, and maybe it'll reset your window. If that doesn't work, then take it to the dealer!
razah9
I press down and it'll go down a couple of inces before closing itself. werid...
leeroy300
Car: Altima Coupe 3.5 SE CVT , niagra gray
never mind me miss read your post sorry
2008CodeRedCoupe
Car: 2008 Nissan Altima Coupe 3.5SE 6 M/T "Code Red"
id say just take it to the dealer, dont bother trying to fix it. they will fix it for free, sounds like it might have a window motor or regulator problem.
cuzzbubba420
Car: 08 Altima 2.5 S w/ CVT
Thanks man I am having this problem with my auto-up feature and couldn't figure out what the heck happened. But when i read your post I had un-plugged my battery to install my new injen intake so I need to go through the reset process as you stated.. THANKS AGAIN!!
