DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Sun Nov 27, 2011 11:32 am
Actually, if the window won't go down and the door panel has never been off there may be a problem removing the inner door pillar cover under the seatbelt post, as you have to access a back side screw holding the piece on the door through the black plastic cover on the outside, and under the door glass unfortunately.
It's such a PITA to remember to have the window down a bit as you replace the door panel, and the screw is inset and you're unable to hold it in place so it falls into the door unless you tape the screw to a screwdriver...so I usually just leave it out as the seatbelt post holds the top tight without the screw in place.
