window noise
AkademikONE
whenever i'm on the freeway, i hear air going through my passenger side windows, and i noticed that the window isnt flush againts the black rubber on the frame where it rests on the top (if you get what im trying to say) what can i do to stop the hissing noise of air coming in...
Eklectrick
Car: Photography, Computing
do you get water leaking in too? if not, you may want to live with it.otherwise, if you must, check the rubber seal and see if it looks good and hasn't ripped or disintegrated anywhere. also look for freeplay in the window itself. if your door shuts solid and your window is loose, it may need adjusting or replacement.
