wickedpelf »
https://forums.nicoclub.com/wickedpelf-u5280.html
Tue May 17, 2005 7:54 am
heres what went wrong with my window, but mine was DS... if you take the panel off the driver door you see a black box with a connection junction on it, take the connector off and then take a flat screw driver, and bend the terminals closer together...or top row down bottom row up, just a little bit, and it should work...you may just be loosing the electrical connection?
