SilviablhS14 »
https://forums.nicoclub.com/silviablhs14-u178400.html
Fri Sep 16, 2011 7:54 pm
The S13 ones will not work. They are a different design than the S14. If its the driver side one I would just go some place that has a warranty on them because you might be replacing the motor again before the warranty is up. This is because of the window switch. It will get stuck in one direction and then the motor will burn up causing you to have to replace it again.
I've replaced 3 of them in the past year or so.
