Upon pushing or pulling the switch all that was heard was a little "click". The motor did not even attempt to move up/down...just a click. THe "click" became more and more frequent until now. I cannot even roll my window down (thank god its up :p) ever. The passenger side worls flawlessly yet the drivers side just give the little "click" sound. I pulled the panel apart and ALL the wiring is exactly as it should be. I am not positive but I think the wiring from the switch board (locks and windows) goes directly to the window motor.... I did not follow them that far.
my questions: Is it possible that it is the motor? Since the switch board is all one peice and I cleaned it out AND the passenger side and door locks are working fine. Or is there some kind of switch in between the one you push and the window motor? If so; could it be the switch that is faulty of some sort since its making a "click"?
I do not have a voltmeter incase anyone suggests it
