TimelessClassic wrote:Hi,
My '03 Coupe has 110K miles and is out of warranty. The driver's side window doesn't work. It needs a new motor and regulator. Where can I get this done? The dealership charges $450 for parts and $450 for labor.
Thanks.
I did a quick search in google and found this
http://www.autopartswarehouse.com/searc ... ndow+motor
You could call & make sure you get the correct motor.
I would also check with a couple of local body shops. They may be able to obtain the parts cheaper as well as cheaper labor.
Good luck
Telcoman
