teojim wrote:So I looked at the links that you mentioned but it talks about removing the whole panel off the door. Do I need to do this just to change the switch panel for the windows that located on the door armrest?
If anybody has an experience in replacing the drivers side window switch panel, please let me know. Not being able to roll down my window while driving, is driving me nuts.
Teo
So, yes, you need to remove the panel to access the switchboard this car. Remove the panel, then flip it over and unscrew the switch.
On the plus side, you only have to fuss with 3 screws hidden under 2 panel covers (one under the armrest anf the other behind the door handle) then give the panel a healthy tug to release the push clips hidden within the door panel... of course balance the panel to unclip the one or 2 major harnesses that might be holding it to the door.
I honestly thought it was one of the most convenient ones I've done.
