window leak
jza80king
Car: 1992 Nissan 240SX
1998 Toyota Supra Turbo
I have a 92 240, everytime I wash my car with a pressure washer the windows leak. Not much just a few drops but its both sides right by the side view mirrors and also along where the seatbelt tracks run. You know where the window meets the roof of the car? I was thinking maybe the rubber that goes along the window is maybe not sealing correctly. Anyone have similar issues? any fixes to this?
nando
Car: 1995 nissan 240sx se
1989 nissan 240sx
if the glass has been pulled before then chances are the installers did not do a good job... having a glass place remove and install the glass might fix the leaks...
i have a 95 240sx and the 1/4 glass leaks also... the urathane that attatches the glass to the body may be seperating.
hope this helps
good luck
