Window issue - regulator or other?
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
biggie
Worked on the way home, then when I opened the door at home it didn't go up/down with the door and only clicks at the switch, does nothing.
Is it the regulator, motor, or other?
Thanks
joe603
Car: 2014 Durango R/T
Sounds like the switch...try holding the unlock button on your fob and see if the window goes down. Then use the key in the driver's lock to put it back up....order the switch.
biggie
Apparently from searching it's the motor actually. Slamming the door a few times got it working for now.
joe603
Cool, time for a replacement! Check out these guys: http://www.car-part.com/cgi-bin/search.cgi
rickybobbyg35
Car: 2004 g35 coupe
so then its the motor? i have a 2004 g35 coupe and the driver side motor is doing the same thing, i have to bang the door in order to be able to get it to go up or down, but when i close the door it doesnt go up or down the way it should automatically.
Return to “G35 and G37 Interior, Exterior and Audio”
